I have been struggling for some time with two issues. One is that Eclipse had numerous unresolved inclusions. I don't know why but that has disappeared for the moment. It may be that you simply have to wait after a build.
I followed the instructions kindly provided by ESP_Sprite here https://www.esp32.com/viewtopic.php?f=12&t=21007#p76800 to configure my ESP32-C3 Devkit for USB. This is tricky because the resistors are so small, but I got it done.
Thereafter I could compile and upload code via the built in USB. Occasionally, for some reason, I had to manually reset but otherwise it was fine.
I had many challenges getting OpenOCD to work. I was able to use this tool https://visualgdb.com/UsbDriverTool/ to install the libusb-WinUSB driver, which allowed me to connect to the target board.
After much trial and error, I noticed that in the In Debug Configurations, Debugger tab
GDB Client Setup/Actual Executable was
<user> .espressif\tools\xtensa-esp32-elf\esp-2020r3-8.4.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-gdb.exe
I modified this to
<user> .espressif\tools\riscv32-esp-elf\1.24.0.123_64eb9ff-8.4.0\riscv32-esp-elf\bin\riscv32-esp-elf-gdb.exe
I then got an error which I was able to determine was because GDB expected a 64 bit CPU. This is because the default is 64 bit to you need to include
GDB Client Setup/Other Commands
set arch riscv:rv32
After apply, I can now debug
Successful ESP32-C3 Built In USB JTAG!
Re: Successful ESP32-C3 Built In USB JTAG!
Hi BrianP,
Awesome news! Thank you for sharing your experience.
One thing though.
Besides the unresolved inclusions (which come and go), I cannot get Openocd to program the device first.
openocd -f interface/esp_usb_jtag.cfg -f board/esp32c3-builtin.cfg -c "program_esp blink.bin 0x10000 verify exit"
<stuff left out>
<path to scripts>\scripts/target/esp_common.cfg:101: Error: invalid command name "esp"
in procedure 'program_esp'
at file "C:\Users\bjpic\.espressif\tools\openocd-esp32\v0.10.0-esp32-20210401\openocd-esp32\share\openocd\scripts/target/esp_common.cfg", line 101
Therefore, I have to select the run configuration, compile and program, switch over to the debug configuration, and debug. I don't know anything about OCD so I have no idea what this means.
<stuff left out>
Hello guys,
Thank you so much BrianP for the solution!
It works.
I was stuck on this issue for a while.
Best regards
Muchas gracias de compartir la soluccion
José Michel
It works.
Best regards
José Michel
José Michel
Users browsing this forum: No registered users and 34 guests
