Hi all!
Is it any possibility/mechanism to burn ESP32 EFUSE_BLK3 using OpenOCD+JTAG?
Thanks in advance!
Oleg
Burning Fuses BLOCK3 via JTAG
Re: Burning Fuses BLOCK3 via JTAG
Here is simmiliar topic of that matter https://www.esp32.com/viewtopic.php?t=17006
Content creator at https://911electronic.com
Thank you for responding!Michalpu wrote: ↑Wed Mar 10, 2021 12:21 pmHere is simmiliar topic of that matter https://www.esp32.com/viewtopic.php?t=17006
But in that topic author used espefuse utility, which works via UART
Dear forum moderators (espressif official), please answer my question
Thanks in advance!
Oleg
I don't think we have any easy-to-use support for burning fuses in OpenOCD. (Checking with a colleague, will come back to this if I'm wrong.) You can technically still manually burn the fuses by directly writing the eFuse registers in OpenOCD or GDB, but that's a bit fiddly.
Thanks for your reply, ESP_Sprite! Please clarify if the Espressif is planning to add such a function / tool in the near future?ESP_Sprite wrote: ↑Thu Mar 11, 2021 3:49 amI don't think we have any easy-to-use support for burning fuses in OpenOCD. (Checking with a colleague, will come back to this if I'm wrong.) You can technically still manually burn the fuses by directly writing the eFuse registers in OpenOCD or GDB, but that's a bit fiddly.
Users browsing this forum: No registered users and 23 guests
