That's great....yeah I've seen that transistors are connected to IO0 and EN pin.username wrote: ↑Mon May 04, 2020 1:06 pmOK, great you have one. You do not need to press the buttons to get it into flash mode. If you do there is something wrong. There are many knock-offs out there that there is a issue with the timing on the GPIO0 signal which forces you do press the buttons.
The real legitimate boards that are not cheap china clones work just fine without pressing the buttons.
The Serial IC on the board have 2 extra pins routed to 2 transistors to toggle the EN and GPIO0 pins when it receives the signal from USB that it needs to be put into flashing mode.
Upload code without pressing EN and Boot buttons
Re: Upload code without pressing EN and Boot buttons
Hey username, Is this the same for the ESP8266 modules too?
I never used a ESP8266. Just head over to espressif web site and download the schematic for it to see.
I've never had to bother with any of the above on the boards I have that will not program without pressing the boot button.
Instead I have just used a 0.1uf capacitor across the EN and 3.3v pin, normally next to each other.
I did discover this by accident when considering what if I hold Reset Pin positive on reboot for a split second, maybe someone could confirm - good or bad idea ?
It seems to work with all the boards I've used, and does not seem to effect those boards that dont need the boot button pressing, as such I always just added the 0.1uf Cap as a matter of course and can then always program from USB.
I can recommend ElegantOTA and AElegantOTA
Users browsing this forum: No registered users and 74 guests
