How to measure a battery.
jenya7
Postby jenya7 » Thu Aug 13, 2020 7:16 am
I'm planning to power my ESP32 board directly from a battery. How can I measure the state of the battery to alert a user on low battery?
May I apply VCC directly to an analog input to measure the battery voltage?
tommeyers
Re: How to measure a battery.
Postby tommeyers » Thu Aug 13, 2020 1:55 pm
Use a ruler if you want to measure its size. Use google if you want to measure its charge.
IT Professional, Maker
Santiago, Dominican Republic
jgustavoam
Contact:
Postby jgustavoam » Wed Aug 26, 2020 3:07 am
Tommeyers se não quer ajudar, não atrapalha.
Hi Jenya,
If you are using the lithium ion battery to power the ESP32, you can measure the voltage at the battery poles.
But don't connect directly! The input of the ADC pin is limited to 3.3 Volts.
And the lithium-ion battery voltage can be up to 4.2 V in the fully charged state.
Therefore, use a voltage divider with two resistors. (for exemple, two 10 K ohms resistors).
Retired IBM Brasil
dynek=
Postby dynek= » Thu Aug 27, 2020 11:34 am
Jenya,
To stabilize voltage, you may also want to add a capacitor and a resistor "just in case of":
https://github.com/esp8266/Arduino/issu ... -222891420
I've done so yesterday evening to mesure a backup battery for my home automation device (to ensure it doesn't go below 12V, otherwise that means the battery is dying and must be replaced) and it works perfectly.
Edit: that being said the value returned by the ADC and its stability differ when WiFi is turned on :?
Cheers
Users browsing this forum: No registered users and 34 guests
