GROUND's pins of esp32-WROVER-B
Partokus
Postby Partokus » Sun Jun 21, 2020 10:34 am
Hello! Guys, please, tell for what using need this pads under esp32-wrover-b? I suppose it is ground's pads. How do they use?
Re: GROUND's pins of esp32-WROVER-B
Postby ESP_Sprite » Sun Jun 21, 2020 11:19 am
You can connect it to ground, or you can decide not to connect it. From the datasheet: 'Soldering Pad 39 to the Ground of the base board is not necessary for a satisfactory thermal performance. If users do want to solder it, they need to ensure that the correct quantity of soldering paste is applied.' ('the correct quantity' probably means 'not too much' here; you don't want solder paste squeezed everywhere.)
Partokus
Postby Partokus » Sun Jun 21, 2020 12:14 pm
thank you very much!
Users browsing this forum: No registered users and 79 guests
