Hello all,
I'm a bit clueless, about my project.
The problem is, that I can't flash my ESP, even worse, I can't communicate with it, e.g. esptool.py chip_id is not working, then I get the error "All of the 4 available serial ports could not connect to a Espressif device." So in my eyes, for this command, the flash settings are irrelevant, aren't they?
As this page states, to get into the bootloader mode, you only need to tie gpio0 to ground.
https://github.com/espressif/esptool/wi ... -Selection
Maybe you can have a look on my schematic, wether i forgot something.
I used this chip: https://www.conrad.de/de/p/wi-fi-bt-ble ... 25470.html, which should be a ESP32-Wrover.
And yes, I already measured the VCC and the ground pin, the esp should get voltage.
Thanks in advance,
Linus
ESP32-Wrover doesn't flash
Re: ESP32-Wrover doesn't flash
What schematic?
Sry, it didn't upload, here it should be now.
- Schematic_flightcontroller_Sheet-1_20190525101919.pdf
- (57.63 KiB) Downloaded 659 times
Suggest you double-check the datasheet of your module, especially compare to chapter 7. If anything, you can see you're leaving the /EN pin flapping in the breeze; you need a RC network there and you need a way to pull it low when you need to program the thing.
Ok, I assumed, that I can also just pull GPIO0 to low, when I power the chip. I will try, pulling also Enable on low.
Ok, it works now!!! Thank u very much!
Users browsing this forum: Google [Bot] and 46 guests
