Esp32 Devkit v1 PCB Eagle library
leonidesfelix
Postby leonidesfelix » Sat Sep 01, 2018 9:33 pm
Just to share this, i hope help somebody
Its for the 30 pins version
ESP32-DEVKITV1.zip
(2.17 KiB) Downloaded 39137 times
trustmiao
Re: Esp32 Devkit v1 PCB Eagle library
Postby trustmiao » Wed Sep 19, 2018 2:02 am
nice one
NosferatusPB300
Postby NosferatusPB300 » Mon Nov 11, 2019 5:10 pm
Hi, tanks for the lib... I used to use this on my projects, but I want just warnig everyone that there are two erros (pin IO27 and pin GND1). Those pins was wrong conected.
ljavih
Postby ljavih » Sun Nov 17, 2019 8:10 pm
Hi I use one of the libraries I found in the internet for the ESP32 development board, the one with 38 pins. The pin out and everything is correct. The problem is that when I printed the circuit the size of the board is bigger than the real size of the board, hence the ESP32 board didn't fit in the PCB. Actually the size of the board in the PCB fits perfect with an ESP8266 board. Does anyone knows how I could solve this and where I could found eagle libraries I could trust?
Jimyxt
Postby Jimyxt » Thu Jan 09, 2020 4:16 pm
I have corrected the pins assigment in the first submitted file, I also correct the pin separation as the pins are 1000 mils appart (1 inch). I hope it is OK and be useful for everyone. I took the measurements from a board I bough from DOIT.
ESP32-DEVKITV1.lbr.zip
Corrected Version 30 pins
(2.12 KiB) Downloaded 11111 times
westech
Postby westech » Wed Sep 09, 2020 12:42 am
Thank you, I'm learning PCB in the Fusion 360 workspace. This should make life easier.
zorglups
Postby zorglups » Sat Jan 23, 2021 5:49 pm
Thank you very much !!!
Michalpu
Postby Michalpu » Sun Jan 24, 2021 1:44 pm
Are there also Altium libs?
Content creator at https://911electronic.com
Users browsing this forum: No registered users and 43 guests
