QUESTION - ESP32-D2WD + External ESP-PSRAM64
wwwenrico
Postby wwwenrico » Wed Aug 29, 2018 1:25 pm
I purchased and received 3k ESP32-D2WD and 3k ESP-PSRAM64 chips.
I'm designing a board with the ESP32-D2WD and with the ESP-PSRAM64.
At page 9 of the 2.5 version of the datasheet I'm reading this:
"ESP32-D2WD’s pins GPIO16, GPIO17, SD_CMD, SD_CLK, SD_DATA_0 and SD_DATA_1 are used for connecting
the embedded flash, and are not recommended for other uses."
source: https://www.espressif.com/sites/default ... eet_en.pdf
QUESTION 1
Can I use the ESP-PSRAM64 with the ESP32-D2WD?
if yes, how can I glue them?
QUESTION 2
Did you address the internal flash memory in the address space of the PSRAM??????
Best regards,
Enrico Migliore
WiFive
Re: QUESTION - ESP32-D2WD + External ESP-PSRAM64
Postby WiFive » Wed Aug 29, 2018 3:24 pm
1. Use sd_data_2 and sd_data_3, but it is not supported yet so you have to modify idf code
2. No
wwwenrico
Postby wwwenrico » Fri Aug 31, 2018 4:38 am
Dear WiFive,
thank you for your reply.
I'll wait for the IDF to support the ESP-PSRAM64.
Thanks,
Enrico Migliore
kmakhil90
Postby kmakhil90 » Thu Sep 06, 2018 11:16 am
Any update on this PSRAM64 support in idf?
Postby ESP_Sprite » Fri Sep 07, 2018 2:04 am
There's an update waiting to be integrated in master. Note that the upper 4MiB are only supported using a bankswitching scheme, they're not accessible using normal malloc()/free() like the lower 4MiB are.
thethinker
Postby thethinker » Sat Sep 08, 2018 10:06 pm
So If we use those pins for the PSRAM, we won't be able to use the SDcard in 4-bit interface mode anymore, right?
WiFive
Postby WiFive » Sat Sep 08, 2018 10:13 pm
No, sd card uses hs2 pins
Users browsing this forum: Bing [Bot] and 56 guests
