ESP32 Supermini deep-sleep consuming 400uA
borelg
Postby borelg » Mon Feb 17, 2025 7:12 pm
I am studying the ESP32-C6 supermini.
I do not have the schematic, but I suppose it to be the same as the ESP32-C3 supermini.
https://dl.artronshop.co.th/ESP32-C3%20 ... asheet.pdf
The battery controller is the following:
https://www.lcsc.com/datasheet/lcsc_dat ... 841234.pdf
The LDO regulator for the 3.3V is the following:
https://www.monolithicpower.com/en/docu ... t_id/1239/
I tried to supply directly the 3.3V at the regulator's output, but when I set the ESP32 for deepsleep with the following code I get an absorbed current from my source of 400uA. I expected this to be in the range of 10uA.
#include <Arduino.h>
void setup() {
  Serial.begin(115200);
  delay(1000);
  Serial.println("Entering Hibernation-like mode...");
  // esp_sleep_pd_config(ESP_PD_DOMAIN_RTC_PERIPH,   ESP_PD_OPTION_OFF);
  //esp_sleep_pd_config(ESP_PD_DOMAIN_XTAL,         ESP_PD_OPTION_OFF);
  esp_deep_sleep_start();
void loop() {
  // This will never be reached
If I remove the comments from the following commands, the esp32 remains always at 20mA consumption:
Do you have any idea why this is happening?
Thanks in advance!
mikemoy
Re: ESP32 Supermini deep-sleep consuming 400uA
Postby mikemoy » Tue Feb 18, 2025 12:46 pm
Did you try to remove the regulator? How do you know you're not back feeding it in some way.
borelg
Postby borelg » Thu Feb 20, 2025 6:50 am
I did not. I supposed there was a mechanism to block reverse current.
I will try and get back here with the result.
Thanks!
Users browsing this forum: No registered users and 89 guests
