PCB vias around ground pins
iwanttolearn
Postby iwanttolearn » Wed Nov 06, 2024 8:05 pm
Hello. I have seen in multiple footprints of ESP32-S3-WROOM-1U that there are vias around the central ground plane like in this image
Image (https://ibb.co/vLcg8hp)
What is the use of this? And can I just remove them, or at least put them on the ground pins? I'm getting A LOT OF rule errors because of these vias.
username
Re: PCB vias around ground pins
Postby username » Fri Nov 08, 2024 9:47 am
It's to connect the 9 pads to the GND.
I'm guessing your getting errors because your are just placing via's there with no connection.
You need to connect these vias to the pads.
iwanttolearn
Postby iwanttolearn » Wed Nov 13, 2024 9:51 am
Thank you. I also was assuming these should be connected to GND, but the footprint I got had all those vias connected to nothing, causing KiCad to give lots of DRC errors.
Users browsing this forum: No registered users and 111 guests
