hi
i have the above board and this are the pins:
my question : there are a few pins which are bound to different things like IO8 is U1RXD as also b(lue)0 for parallel output pin for display.
So it is possible to share pins between different functions? The pins on the right like SPI 2 is for the TFCard as also for SPI. So could i use SPI (an 4pin expansion on the board) and the TFCard simultaneously?
Someone any ideas
regards
hape
JC8048W550-C Pin distribution question
Re: JC8048W550-C Pin distribution question
[quote]Serial Number Pin Notes Connect
1 IO8 U1RXD DB1(B) b0
2 IO3 DB2(B) b1
3 IO46 DB3(B) b2
4 IO9 DB4(B) b3
5 IO1 DB5(B) b4
6 IO39 HSYNC x
7 IO41 VSYNC x
8 IO40 DE x
9 IO5 DB6(G) g0
10 IO7 DB8(G) g2
11 IO15 DB9(G) g3
12 IO16 DB10(G) g4
13 IO4 DB11(G) g5
14 IO45 DB13(R) r0
15 IO48 DB14(R) r1
16 IO47 DB15(R) r2
17 IO21 DB16(R) r3
18 IO43 U0TXD TX
19 IO44 U0RXD RX
20 IO0 BOOT I2S-BCLK/L3
21 IO18 I2S-LRCLK/L2 UART1/USB 2 P4 4
22 IO10 SPICS0 TF(CS)
23 IO11 SPID TF(MISO) SPI 2
24 IO17 U1TXD IS2-DIN/L1 UART1/USB 1 P4 3
25 IO38 TP_CS
26 IO2 BL_C
27 IO37
28 IO36
29 IO35
30 IO14 DB17(R) r4
31 IO20 USB_D+ TP_SCL UART1/USB 3
32 IO12 SPICLK TF(SCK)/TP_CLK SPI 3
33 IO13 SPIQ TF(MOSI) SPI 4
34 IO42 PCLK x
35 IO6 DB7(G) g1
36 IO19 USB_D- TP_SDA SPI 1 UART1/USB 4
GND GND P4 1 P5 4
3,3V 3,3V P4 2
5V 5V P5 1 P5 2 TXD P5 3 RXD[/quote]
Users browsing this forum: Google [Bot] and 36 guests
