Flash Erase completed but without effect
Pommesfreak2
Postby Pommesfreak2 » Thu Feb 09, 2023 9:04 am
Hello fellow programmers, when I tried to upload a new programm to my ESP32 WROOM DA-Module via Arduino-IDE I did receive following error:
Error while writing flash: MD5 of file does not match data in flash!
Found a possible solution: erasing the ESP's Flash via esptool.
So I installed esptool tried many different commands like
python -m esptool --chip esp32 erase_flash
All of them detected the boards and seems to work as they give me following like code in response:
Connecting.........
Chip is ESP32-D0WD-V3 (revision v3.0)
Crystal is 40MHz
MAC: c0:49:ef:cd:bd:b8
Uploading stub...
Running stub...
Stub running...
Erasing flash (this may take a while)...
Chip erase completed successfully in 0.0s
Hard resetting via RTS pin...
Even though it seems to worked the Error when trying to write the flash keeps the same.
Furthermore the programm that was on the flash before the erase is still there. So there was no real erase.
I also tried an online version: https://espressif.github.io/esptool-js/
It's interesting that erasing the flash is that fast - most videos I saw had a time about 2 seconds. Maybe a part of the problem.
I'm using a Windows 10 64x PC and a ESP32 Wroom-Da-Module. Please tell me if you need something in addition to these information, I'm not very experienced in things like these :)
Re: Flash Erase completed but without effect
Postby ESP_Sprite » Fri Feb 10, 2023 2:16 am
This tends to be an issue with GPIO12 connected to the wrong voltage level. Do you have that pin connected to anything?
Pommesfreak2
Postby Pommesfreak2 » Tue Feb 14, 2023 9:11 am
No, GPIO12 is not connected to anything.
corz.org
Contact:
Postby corz.org » Thu Mar 16, 2023 10:49 pm
How is this a "Showcase"?
Postby ESP_Sprite » Fri Mar 17, 2023 2:32 am
It's not, moving it to another forums. Thanks for noticing, but next time please report the topic rather than replying, it's a cleaner solution.
rsimpsonbusa
Postby rsimpsonbusa » Tue Mar 21, 2023 10:51 pm
I had that problem with a module. I actually changed the internal flash and that error message disappeared. just my 5 cents
Users browsing this forum: Bing [Bot] and 27 guests
