ESP32-WROOM-DA-N8 Dual radio?
drprez
Postby drprez » Mon Jan 02, 2023 12:54 am
I need to have the ability to connect to both Wi-Fi and Bluetooth simultaneously. I wanted to use the ESP 32 and add a second radio module. My thought is the ESP 32 would handle the Wi-Fi connection and then the module would connect directly to a Bluetooth speaker..
I originally had used a Wemo d1mini, which handle the Wi-Fi connection and the code. And then I simply connected to the D 32 to pin 16 which handled the Bluetooth only. But that was way underutilizing the power of the ESP 32.
Recently I saw the ESP32-WROOM-DA-N8 dual antenna. Is the have 2 radios so you can run Bluetooth and WiFi at the same time?
The second problem is I had to program each board individually, the D1 and the 32. Where if I ran everything on the ESP 32. I'm hoping I can do one programming.
So my thought is to move everything over to the ESP 32. My only problem is I can't run both Wi-Fi and Bluetooth at the same time because there's only one radio. So
My only other need is on the ESP 32 to activate some RGB light by a simple 4 pin connection.
-what is the most cost-effective way to add the second radio?
-or how to do it?
-or is there a better solution?
-I need a solid, reliable Wi-Fi connection that is stable which is part of the problem. I have with a D1 mini is that it's not very stable and disconnect often.
-My need is do you have a constant connection by Wi-Fi. As well as being constantly connected to a Bluetooth speaker that would play audio when the signal was sent to it.
My original code was written on the arduino IDE.
Users browsing this forum: No registered users and 30 guests
