Hi, I purchased a couple of ESP32-C3 mini modules for a project. The modules are being mounted on PCB board, I tried to flash/program them for the application using a customized board (simplified schematic of esp32-c3 dev-board). The issue is that the system is unable to communicate with the module. I also replaced the module on an esp32-c3-mini dev board with the purchased one but still facing the same issue with the flashing. The question is that:
Whether the esp32-c3 modules, in the market, are required to be pre-programmed prior to the flashing process?
How I can flash the modules?
Any help/comment/guide will be appreciated!
Best Regards,
Mahdi
ESP32-C3 MINI-1 module programming
Re: ESP32-C3 MINI-1 module programming
I just spent quite a bit of time figuring out why I couldn't upload to my own boards, so I appreciate what you're experiencing.
The ESP32-C3-Mini modules do not need to be preprogrammed. You can write firmware to them directly using esptool.py
I programmed mine using the Arduino IDE, which uses esptooly.py under the hood.
If you share what your custom programming board looks like, we might be able to help.
Users browsing this forum: No registered users and 31 guests
