ESP-WROOM-32D randomly shuts down and doesn't turn back on
zosayed
Postby zosayed » Wed Oct 26, 2022 9:41 pm
Hello, I am using an ESP-WROOM-32D and it runs 24/7, I used to connect it to power using the micro usb with a phone charger plug, but then I read it isn't reliable so I cut the wire and connected it directly to the 5V and GND pins but it doesn't make a difference.
The ESP randomly shuts down after about an hour or so of usage (it uses TCP if thats important), what could be the issue?
I will attach an image of the plug
aid219
Re: ESP-WROOM-32D randomly shuts down and doesn't turn back on
Postby aid219 » Fri Oct 28, 2022 11:24 am
what are the symptoms? when the shutdown occurs, do the LEDs of the board continue to light?
Postby ESP_Sprite » Sun Oct 30, 2022 2:18 am
Given you suspect the power supply, have you already tried using a different USB adapter to see if it still does this?
Users browsing this forum: No registered users and 45 guests
