ESP32-DevKitM-1 Development Board is a single or a dual core board?
ALGONSI
Postby ALGONSI » Sat Jul 09, 2022 7:37 am
Hello.
In the ESP32-DevKitM-1 Development Board documentation (https://docs.espressif.com/projects/esp ... itm-1.html) we can read:
! Attention
ESP32-DevKitM-1 is a board with a single core module, please enable single core mode (CONFIG_FREERTOS_UNICORE) in menuconfig before flashing your applications.
On the other hand, this board incorporates an ESP32-MINI-1 module which, according to the documentation (https://www.espressif.com/sites/default ... eet_en.pdf), is a dual-core microprocessor:
1.1 Features
CPU and On­Chip Memory
• ESP32-U4WDH embedded, Xtensa dual-core
32-bit LX6 microprocessor, up to 240 MHz
Could you please explain this apparent contradiction?
Thank you and have a nice day!
Re: ESP32-DevKitM-1 Development Board is a single or a dual core board?
Postby ESP_Sprite » Sat Jul 09, 2022 1:18 pm
I think it used to use a Solo chip, but we changed things later on. It may depends on the specific devkit.
ALGONSI
Postby ALGONSI » Sat Jul 09, 2022 1:52 pm
Thank you ESP_Sprite for your answer.
In my question I have made reference to a specific development board and a specific microprocessor.
Could I have a more specific answer, please?
Postby ESP_Sprite » Sun Jul 10, 2022 2:18 am
I mean, it may depend on the specific devkit as in the actual piece of hardware in your hands, not the model. If the ESP32-DevKitM-1 you get is older, it may have only one usable core as it says in the specs; if you get one that is newer you may have an usable extra core for free.
ALGONSI
Postby ALGONSI » Sun Jul 10, 2022 5:20 am
Now I understand. Thank you very much!
ALGONSI
Postby ALGONSI » Mon Jul 11, 2022 5:32 am
BTW, there is conflicting information in the ESP Product Selector https://products.espressif.com/#/product-comparison and the ESP32-MINI-1 Datasheet https://espressif.com/sites/default/fil ... eet_en.pdf:
In all versions of the ESP32-MINI-1 Module it says
CPU Xtensa® single-core 32-bit LX6
Core 2
and in the Datasheet it says
Built around ESP32 series of SoC, Xtensa® dual­-core 32­bit LX6 microprocessor
So, is the ESP32-MINI-1 Module single-core or dual-core?
ESP_krzychb
Contact:
Postby ESP_krzychb » Mon Jul 11, 2022 6:36 am
Hi ALGONSI,
ESP32-U4WDH chip variant installed inside ESP32-MINI-1 module has been upgraded from single to dual-core in December 2021. This information is covered in ESP32 Datasheet on page 52 in the footnote. After that date, newly manufactured ESP32-MINI-1 modules and then ESP32-DevKitM-1 boards should contain the new dual-core chip.
Further details on this change are in PCN-2021-021.
I am sorry for the confusion. The note in the ESP32-DevKitM-1 user guide and the information about ESP32-MINI-1 in the ESP Product Selector will be updated soon.
ALGONSI
Postby ALGONSI » Mon Jul 11, 2022 8:28 am
Thank you very much ESP_krzychb !
Users browsing this forum: No registered users and 37 guests
